No start
  • Shayneboy
    • Mar 2017
    • 27
    No start
    Hey guys, I have a 1985 325e and it was running fine until it started sputtering, then when I applied the gas, it sputtered more and eventually died. When I turn the key, I can hear the fuel pumps turn on, the lights are on but when I turn the key, the lights go dim. Could this be a battery issue or starter or alternator? I originally thought that it was because the motor might have overheated, I smelled coolant and saw some leak from under the car. Car has always ran fine. Any suggestions? Any ideas on what it could be?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5611
    Best plan of attack is to search this forum for "no start" issues. That will turn over results much faster than starting a thread. Every no start issue has been addressed, a bunch of times.
    But, maybe I can help you out..
    Is it cranking, or is it a no crank situation??
    • Shayneboy
      • Mar 2017
      • 27
      No start
      No crank
      Sent from my iPhone using Tapat
      • cheffy30
        • Sep 2016
        • 1159
        relays
        '90 325i sedan daily driven
        '85 325e coupe also a daily
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5611
          Check the battery voltage. It sounds like your alternator took a shit.
          • Shayneboy
            • Mar 2017
            • 27
            The battery was at 12 volts
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5611
              Originally posted by cheffy30
              relays
              • Shayneboy
                • Mar 2017
                • 27
                Anything specific? Or should I just get a bunch of new ones from a parts store
                • cheffy30
                  • Sep 2016
                  • 1159
                  Under the steering column there is one specific to the ignition.... Take a look there.. Unplug replug..
                  Sent from my HTC One M9 using Tapatalk
                  • Shayneboy
                    • Mar 2017
                    • 27
                    Okay will do. Thank you
