AFM + MarkD chip or MAF+Miller chip
  • ForcedFirebird
    • Feb 2007
    • 8300
    New things have been learned and found out. Tube screen tv’s work but i bet you’ve upgraded to an led/lcd flat screen...
    Not quite the same as software. The hardware (m20 engine) has not changed, so it's not like we recently discovered the m20 can use an extra xx° of timing or xx% more fuel.
    john@m20guru.com
    Links:
    • MarkD
      • Sep 2004
      • 488
      Please supply an example of some "new thing" that you think is important which the earlier tuners didn't take advantage of. I'm curious what you are thinking of.
      URL: www.dsylva-tech.ca
      • DesertBMW
        • Aug 2011
        • 1042
        Originally posted by MarkD
        Why does a chip that works need an update?
        Software can always be improved
        That information would be proprietary. But I can say what I did sense all of my work is free to share. I erased the 8 timing and 8 fuel maps that stock DME uses and forced it to use one bigger resolution timing map and one bigger resolution fuel map
