New Plugs, Rotor, Ignition Coil, Etc. & Still Won't Start
  • FrictionTape
    • Sep 2016
    • 49
    New here and have used search to sort out some of my issues already.
    I have a 1987 325is that seems to have some significant electrical issues that I just can't figure out. The car will turn over, but I am not getting a spark. The fuel tank has been removed and internal tank removed if that makes a difference.
    We've installed a new crank sensor (plugged into the right terminal), spark plugs, rotor, distributor cap, ignition coil and spark plug wires. We're getting 12 - 13v on the positive terminal at the coil and the battery is in good shape.
    We've tried three different Montronic ECUs and still no spark. What am I missing, what else should I be looking at?
    Thank you!
    That sounds like it could be a problem in the wiring harness.I would use my o'scope to look at the CPS signal at the DME connector.
    • redlightpete
      • Mar 2012
      • 265
      The Bentley manual has a list of electrical tests that you perform at the dme connector. This can help find wiring problems.
