Compression test results
  • parkerbink
    • Jun 2004
    • 10138
    Originally posted by TobyB
    Heh- with carbs, if it'll stay within 7% of where you want it
    over the entire rev/load range, you're doing pretty well.
    But I digress.
    t
    Problem with carbs? Atkins diet.
    I see your digression and further digress.
    • Dillon
      • Oct 2017
      • 38
      Well I just ran a 160 as my highest psi and 150 as the lowest on a dry test. (all other cylinders between). I did mine cause I was afraid that I put a hole in a piston when I pulled the injectors and found them looking lean as can be with bits of material on them.
      AND IT'S GOT BIGGER M50 INJECTORS!! so lost.
