e30 rear driveshaft flange
  • LicketySplit
    • Jul 2017
    • 28
    Thank you for the replies!!
    Mod please delete.
  • redlightpete
    • Mar 2012
    • 266
    There is a cap on the end of the driveshaft half where the splined section fits in. It has a hex on one end. You need to loosen this cap to extend or compress the two halves of the driveshaft. The two halves come completely apart, so you may want to mark their rotational position to each other in case you pull them apart accidentally.
    • LicketySplit
      • Jul 2017
      • 28
      i believe you are talking about the center part of driveshaft. i need the rear end of the driveshaft (the flange is studded) that bolts onto differential.
      • Seawolf
        • Feb 2015
        • 270
        Look inside that sleeve forward of the UJ assembly, do you see a large collar nut ?
        • LicketySplit
          • Jul 2017
          • 28
          yes hex shaped. i just loosen that collar nut ?
          • Seawolf
            • Feb 2015
            • 270
            Yep
