M20 Config
  • Raceport
    • Jul 2017
    • 4
    M20 Config
    All greetings from Moscow!
    In 2018 I want to take part in the local championship of Youngtimers. But for along time did not work with engines of type M20. Tell me briefly so as not tobreak the technique.
    The configuration is planned:
    M20B25
    cam-shaft Schrick. Lifting the valve 12.2 phase 304
    Springs Schrick
    Rokers RH Engineering
    Stock intake manifold
    Exhaust manifold made in USA no name :)
    Can you set this on thefactory DME?
    Are there any problems with this configuration? Can not eat parts compatibility?
    I write through an electronictranslator I hope the meaning will not be lost. J
    Thankyou
  • Raceport
    • Jul 2017
    • 4
    Who used these adjusting screws in the M20? How are they at work?
    CB Performance - High Performance Racing Products, CNC Ported Cylinder Heads, Carburetor Kits, Ignition, EFI Systems, Turbo Kits, Long Block Engine Kits, Disc Brake Kits, Drop Spindles, Suspension Parts, Dune Buggy and Sand Rail Parts for Aircooled Volkswagens.
    • digger
      • Nov 2005
      • 6195
      Who is RH engineering?
      If you mean rhd then that cam won't work you need their cam to.
      Regardless the piston won't accomodate that cam the valve will hit piston
      Don't use the factory dme it's not good with race camshafts
      • Raceport
        • Jul 2017
        • 4
        • Raceport
          • Jul 2017
          • 4
          This rocker will be bad with a camshaft so that I have?Is the roller a roller or a bearing?
          • digger
            • Nov 2005
            • 6195
            you need one the the RHD cams for the RHD rockers, of which there are 3 profiles i know of. it wont work with a normal cam from schrick, bmw, catcams or anyone else. if you want to use a schrick and billet rocker there are a few other companies that make them
            the RHD rocker is a roller follower that runs on the cam as opposed to the sliding follower. it use a needle bearing.
