So I have 2 c101 connections. The fuse box c101 on the car is the original for a 87 325es, the other from the ECU is off a 1989 or 90 325ic. I've been told the grounds are different but I'm bad with wiring and I'm trying to figure out what goes where. The harness side has 16/20 pins and the fuse box side only has 11/20.
Pin 7 on the harness have 2 green wires and pin 10 an 1 both have blue.
I just need some help on what I can do so I don't fry it and so I keep everything working.
Sent from my XT1635-01 using Tapatalk
