M20 Crank OT Marks Not Aligned?
  • HerbE30
    • Nov 2015
    • 538
    When replacing the timing belt; I have the cam sprocket aligned and checking the crank (either against the cover and sprocket OR with the sprocket off and checking against the block) there is about 5 degree or 1 tooth off. I am going to pull the belt and re-align them.
    Is this wrong? Make sure both are in line and throw the belt on? I assume with would be better than leaving it out of line.
    Also, the cam sprocket is reverse torx?? 50mm correct?
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • digger
    • Nov 2005
    • 6119
    Align them. It is not reverse thread
    • HerbE30
      • Nov 2015
      • 538
      I did just align them. I wanted a second input, so thank you.
      I think I meant to say female tprx instead of reverse torx. Similar to the updated head bolts.
      20% Accurate
      • digger
        • Nov 2005
        • 6119
        Needs a socket female type torx drive e10 or e12 iirc
