Weird distributor cap problem
  • aguiarjason
    • Sep 2016
    • 10
    What the hell is happening with my rotor and cap??? I had just replaced it because the last one for some reason the rotor was shattered, and a couple pins on the cap were missing.
    So i replaced it and now it has broken again. This time only the cap broke, 2 pins completely gone. Also some white kinda powder was between the cap and in the rotor.
    Not sure what could be making this happen, both times.
  • zaq123
    • Jul 2016
    • 1502
    I'd remove the rotor and check cam sprocket bolt asap...
    • Seawolf
      • Feb 2015
      • 270
      Does your car have the lifting plate in place behind the cam belt cover ? If it's missing then the cam belt cover will distort when tightened down and mis-align the distributor cap - then the rotor destroys itself and cap.
      • aguiarjason
        • Sep 2016
        • 10
        THANK YOU MY MAN, I’m assuming it is this. I completely forgot it when putting everything back together.
        • Seawolf
          • Feb 2015
          • 270
          Yes, that one. Refit that and you should be good - though your dizzy cap looks beyond saving :)
