Valve cover breather hose??
  • Paul-Z
    • Jan 2018
    • 159
    Does someone have a schematic or can maybe describe to me how the hose gets run underneath the intake manifold? I removed mine a few months ago and can’t remember. Every route I tried the hose gets kinked typically against the fuel rail on the first 90 degree bend coming off the cover.
  • zaq123
    • Jul 2016
    • 1559
    it goes over the fuel rail. Sure you got the correct hose?
    • Paul-Z
      • Jan 2018
      • 159
      Thanks. Yes I believe I have the right hose. I’ll try again.
      • dnguyen1963
        • Nov 2011
        • 2651
        I tied a rope to one end of the hose then pulled it through. You'll spend a lot of time trying to push that hose.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5591
          I've never had a hard time just feeding that sucker from the TB towards the VC.
          It goes over the fuel rail, so if it gets caught, just use a long screwdriver or whatever to guide it a little bit.
