I've recently been going through the process of eliminating coolant leaks. Starting with a bad radiator cap, radiator hoses, thermostat, heater hoses, and ultimately, the water pump with a new timing belt. When I was finally done, I started filling up with coolant, and immediately coolant started running out. My neighbor helped me run a pressure test, and a small stream came spraying straight out from what appears to be the headgasket, directly above the waterpump where the pin and spring for the tensioner contact the waterpump. I didnt think there were any coolant passages at the very front of the moter in this area. Has anyone else ever seen or experienced this?
strange headgasket coolant leak
