M20 single tooth cam sensor input
  • 91BMWE30
    • Jun 2016
    • 14
    I searched everywhere and I cannot find any definitive information on how to setup a single tooth m50 cam sensor on my m20 in megasquirt... on the DIY Autotune website it states to make the angle 360° from the tooth #1 angle. I cannot understand what that means exactly. I am trying to use it on MS3x.
    Link to website -> https://www.diyautotune.com/support/...-your-bmw-e30/
    If anyone can chime in with information it would be much appreciated.
  • TobyB
    • 5298
    What it wants is cam position information. Which they are saying to
    get from the distributor, which makes good sense.
    The 360 degrees is crank degrees, so it's really just saying to set the index pin
    for the sensor 180 CAM degrees before top dead center, then delay it in tunerstudio.
    Or something like that. I last played with Megasquirt before it had numbers after it, tho...
    t
