M20 start - no power to DME
  • E30335i
    • Feb 2014
    • 1035
    Read no start guides and printed out etms for ground and power for dme pins and c101
    I have ‘88 e30 m20 late model w/ 1.3 motronic. No light for dme. Made sure the light wasn’t out by checking voltage at coil with ignition on. No voltage so definitely towards dme. To start off I don’t get power from the inline fuse so it’s bypassed with a wire from the big wire on the junction block back to the wire. Made sure there is power there too.
    Dme relay has battery voltage but not clicking when connected. Verified relay works by checking it with power probe.
    I forgot which pins on dme but there is one that is a hot wire constant voltage and it had battery voltage. Verified w/ power probe and circuit tester. The other two pins had no switched power with ign on.
    I’ve tried 2 separate dme’s & harness’.
    Always have noticed on c101 pin 7 does not have any voltage. I still have to check the obc relay & pin 27 dme which gets power from the obc relay but figured give it a shot here and put the flame suit on if I’m overlooking something.
  • 95BMWIC
    • Apr 2012
    • 353
    I would try switching out the relay just to eliminate it (I know you tested it)- its a cheap part - I say this because you have "tried 2 separate dme's". and I have seen relays act real funny. This could cause a no start issue and issues in testing the DME
    • E30335i
      • Feb 2014
      • 1035
      I have multiple that I’ve tried and received no results. Also bypassed the obc relay. No results.
      Noticed pin 7 has no voltage and is important for supplying power to the dme. Gonna start over fresh using via the no start page on e30 wiki
      • e30davie
        • Apr 2016
        • 1788
        Presumably you have checked all the fuses?
        • E30335i
          • Feb 2014
          • 1035
          Yeah of course
          • 95BMWIC
            • Apr 2012
            • 353
            Ok - just to walk through this.
            Is your ignition on when performing the test? It doesn't specifically say this when testing main relay - but I am "guessing" it would be on.
            You are trying to figure out why no power to the DME - but you state on your first posting you have power? "hot wire constant voltage and it had battery voltage"
            So you tested the main relay by testing terminals 36 and ground (thats what I am seeing in the Bentley anyway - I believe it is the same pins as the 1.1) for Main Relay control and you ARE NOT getting a click when 36 is touched to ground? On any of the relays and no DMEs Nor with any different harnesses?
            Did you have continuity - of the new harness - when you plug the harness in?
            Im not sure of the difference but here is another reference on the 1.3 ECU.
            BMW E30 ECU pinout and electrical tests: where the ECU lives, how to access it, and pin-by-pin diagnostic checks.
            Other thoughts - Is this a no start? Is this why you are focused on the DME?
            I dont understand this statement
            "Made sure the light wasn’t out by checking voltage at coil with ignition on. No voltage so definitely towards dme"
            You mentioned no voltage to the coil - so you would have to check the wire between the coil and the ignition switch. When you turn the switch on there should be voltage to the coil. Its either a fault in the wire, the ignition switch itself or the wire to the ignition switch.
            • 95BMWIC
              • Apr 2012
              • 353
              Just thinking more about this
              Pin 7 on C101 is switched power from the ignition switch.. in which you have no voltage.
              So - check the ignition switch. It would also explain why no voltage to Coil.
              Page 15-41 in Bentley.
              • E30335i
                • Feb 2014
                • 1035
                Omg i cannot believe this, obc relay turned out to be the issue. I was going in circles. When I by passed I just stuck a wire & stuck back in for testing but the wire popped out while I was checking around. I feel so good that I actually checked everything pin by pin. Thanks everyone for helping me in the mean time.
