m20 fuel pressure question
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Looking in the bently it says fuel pressure for an m20b25 should be 43.5psi +- 0.9 psi.
    I am getting a steady 36 psi.
    That's the rating for the eta engines... Is this something to be concerned about? Already tested my FPR and confirmed that is not leaking or stuck open/closed.
    When I remove vacuum from the FPR (causing it to close) I end up getting around 46 psi which is right on par with the spec for that test.
    Is this lower than usual fuel pressure something to be concerned with?
  • TobyB
    • 5271
    You're supposed to pull the line- you're fine.
    It subtracts manifold vacuum from atmospheric pressure
    to give a consistent pressure drop across the injector.
    More to the point, 36 psi + .7 bar = 45 psi...
    t
    Last edited by TobyB; 04-19-2018, 07:23 PM. Reason: reading comprehension, not so much with me today
