Timing question m20b25
  • Boostedgmc
    • Feb 2018
    • 5
    I have a new head torqued on and cam is at tdc but the crank is 90 degrees off. Do I have to take the head off again to put the crank at tdc because of interference, or can I just hand crank it with it on?
  • skitzy777
    • Jul 2016
    • 57
    Take out the spark plugs and rotate the crank towards tdc until you feel the valve touch the piston, do it really slowly and apply minimal pressure. Once it touches rotate it the other direction slightly about 10 degrees and rotate the cam in reverse till you get it lined up.
    -E30 323i 1983
    -Honda CB250n 1980
    • Boostedgmc
      • Feb 2018
      • 5
      For tdc one or your saying the next cylinder at tdc?
      • e30davie
        • Apr 2016
        • 1788
        Release all the rocker arms in the head. Then line it all up and then figure out how to reset all the rocker arms again.
        • Boostedgmc
          • Feb 2018
          • 5
          I just took the head off
          • skitzy777
            • Jul 2016
            • 57
            Thats essentially impossible to acheive without damaging anything.
            -E30 323i 1983
            -Honda CB250n 1980
