Location of ABS Relay
  • Echo30V
    • Sep 2017
    • 301
    1990 E30 325i Vert. ABS light on. I can’t locate the relay. It’s not under the dash next to steering column. I understand the later models did not have the relay under the dash. Anybody know where it’s located. If not the relay, why else would the abs light be illuminated? Yes, I already utilized the search function with respect to this issue, ad nauseum.
  • jeffnhiscars
    • Jun 2011
    • 6011
    A bad wheel sensor will trigger an abs light and IIRC the relay was moved from just above the control unit unde the dash to the ABS module itself.
    Alice the Time Capsule
    • Echo30V
      • Sep 2017
      • 301
      So I have open the module?
      • LateFan
        • May 2013
        • 4422
        No, if you pull the pump trim cover, it plugs in next to the pump.
        • Echo30V
          • Sep 2017
          • 301
          Ahh, thanks
