Driving home my check engine light tripped and the car started bucking in gear. The idle would bounce 500-2000 sometimes hold 2000 and then sometimes it would randomly rev to 5000.
Stomp test revealed code 1261 so I replaced the relay and unhooked the battery with no luck. The terminals look ok and the old relays work on my other car.
What should I check next? Could it be a combination of problems? The car only posted one code.
There seems to be no throttle response at all or change in rpm from throttle input.
