I bought an eta a few months ago. Car had been sitting for 2 years. Fuel comes out brown before the fuel filter. Is there a way to completely clean the fuel system so that I can prevent more bad fuel from going in? I think that’s what causing my idle to be rough. Maybe new fuel pump or something?
Fuel system cleaning?
Sounds like your fuel tank has rust in it.2009 BMW 328i xDrive (Daily/winter drift king)
1987 BMW 325i (Currently torn apart)
Instgram: @Ebola.30 -
You really should remove the tank to properly clean it, which is possible if it's light surface rust VS scaling. If you don't do it your filter will get plugged but likely not before it burns out one or both fuel pumps.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
Drain the tank from the bottom. Take the level sending unit/suction off the top of the tank. Use a flash light and look in the tank. See rust remove the tank to replace or have it cleaned and coated. No rust flush system with good gas till clear by running pump and putting return line into bucket. Be prepared to have to drop the tank.Comment
