Sometimes surges other times smooth at idle
  • mjposner
    • Aug 2015
    • 169
    My 325i will sometimes surge between 600-700 rpm at idle, cold or hot, and other times stay steady at 700 rpm. With a/c on same issue, though now 700-800 rpm.
    ICV was removed and cleaned (though not dirty). No obvious vacuum leaks though all rubber is original. Fuel pump is also original.
    Thoughts
  • riskybiz86
    • Feb 2018
    • 45
    Had a similar issues and it was the placement of the O2 sensor. I have long pipe headers and the sensor is only embedded in one of the two exhaust pipes,causing it to surge.
    I unplugged the sensor and it revs much higher at idle but it's stable. So eventually going to pick a better spot for it.
    Hope that helps a little.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5616
      get a smoke test done to verify that there are in fact no vacuum leaks
      • mjposner
        • Aug 2015
        • 169
        Risky, I have stock headers, so not clear if that would still apply.
        • ForcedFirebird
          • Feb 2007
          • 8300
          Where in SFL are you? Can always come by the shop for a diagnostic.
          john@m20guru.com
          Links:
          • mjposner
            • Aug 2015
            • 169
            I am in West Palm/Wellington.
