Hit pothole, engine cut out
  • CaliforniaGrown
    • May 2018
    • 21
    I was on the freeway and hit a pothole and the motor died only thing keeping it going was the fact it was in gear and I was going 55. I was able to coast to an exit and the car wouldn't start up the first few times, and then it was fine. Once it died when my lady slammed the passenger door. Any insight? I have an 86 325e manual. Thanks,
    Josh
  • HerbE30
    • Nov 2015
    • 538
    Did you check grounds? Ensure the battery is secured well? Crank position sensor still the appropriate spacing? Ensure none of the relays or fuses wiggled out?
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
    • 808e30325i
      • 537
      Almost definitely sounds like a grounding issue my ‘87 325es used to do it all the time, then found out it was just one of my leads on the battery that wiggles loose.
      • CaliforniaGrown
        • May 2018
        • 21
        I breifly thought about the grounds, especially the one on the valve cover, since it's covered in oily grime from before I did the valve cover. Ill look into it. Thanks guys I appreciate the help.
        • Reichart12
          • Aug 2012
          • 2168
          Mine had something similar. The battery terminal was loose. Bumps would make the car shutter and sometimes it wouldn't start back up after parking. Cranked that sucker tight and no more problems.
          Instagram: Reichart12
          • wolfador
            • Mar 2018
            • 33
            Originally posted by CaliforniaGrown
            ...the car wouldn't start up the first few times, and then it was fine...
            Was the car cranking and not starting? Maybe a lose connection on the fuel pump?
            86 325e sedan
            • Magnaflow Cat-back
            • SSSquid Stage 1 Chip
