1985 325e runs great but take off and shifts, bog...
  • Lizard 1
    • Jun 2018
    • 54
    So, got my awesome 325 running good. Has a full system with headers on it. When I take off, initially, a bog and then she hits and revs through up to red line if I desire. Then every shift, when I first let out and feed it fuel, she bogs and hits back to normal.
    Any thoughts? It has a few things different other than the exhaust. The previous owner disconnected the charcoal canister and appears the ICV is not there and has been plugged off. It has also been a daily but even before I put the exhaust on it, she had the stumble. Not as pronounced.
    I also put in a new O2 sensor if that would even matter...
    Outside the initial stumble, she runs awesome! Just annoying.
  • Lizard 1
    • Jun 2018
    • 54
    Nobody has any input or thoughts?
    • MB07
      • Jan 2018
      • 62
      Have you done a stomp test?
      Can you get an ICV to test with? Mine ran like garbage when I got it but after I cleaned my ICV it ran much better.
      2009 BMW 328i xDrive (Daily/winter drift king)
      1987 BMW 325i (Currently torn apart)
      Instgram: @Ebola.30
      • Lizard 1
        • Jun 2018
        • 54
        The ICV is not even there. Or at least I cannot seem to find it and the hose that leads to the throttle body is plugged...
        Now, there is a vacuum oriented thing on the driver's side fender next to the air box. Has a vacuum line and looks to be a valve. Is that something that can be cleaned? Not sure what it is called...
        • Lizard 1
          • Jun 2018
          • 54
          Also, food for thought... I think it’s running really rich. It’s got a full exhaust and headers. Not sure that would cause issue as the system should compensate for it.
          But, sometimes, she gets really boggy and acts almost like she’s getting too much fuel and I try to rev it out and nothing but black comes out until she clears up. On the boys at take off and between shifts, same deal. Not white or blue. Black which is indicating fuel.
          Any thoughts as to that? Seems to be some type of either MAF or fuel delivery deal. Has had the fuel pump replaced and not sure what was used. Whines a ton when on and running but I would think if it were a fuel pump, she’d be rough all the time.
          • e30davie
            • Apr 2016
            • 1788
            sounds like a motronic system.
            1 - fix all vacuum and air leaks
            2 - stomp test to find codes
            3- check the temperature sensor to see if it is within spec.
            4- check the AFM resistance to see if its in check
            Report back when complete.
            • dsphil
              • 495
              You will need to install the ICV back regardless. Otherwise you can only set the idle with the throttle partial open and the throttle switch maybe always on. The ECU will running with open throttle all the time.
              327is
              325es
              325es
              318is
              Fiesta ST
              E46 M3
              • Lizard 1
                • Jun 2018
                • 54
                Any thoughts why the previous owner/owners would have eliminated this? Like I said, it runs great, but loads up. Sometimes, I will come to a stop and she will idle perfectly fine. However, when taking off, she bogs and almost stalls and then barely idles and I cannot give it any throttle or she wants to die. Idles for a period of time and then seems to clear out and I can feed throttle and then take off. Loads of black smoke trying to start it as it dies several times.
                • 101
                  • Jul 2011
                  • 764
                  The eta ECU can't be stomp tested.
                  On our eta we chased sililar demons for quite a while. The best medicine I found was following the Bentley manual and testing all the sensors and pins where the harness connects to the ECU (and at the idle control module). Checking in this manner allows you to assess both the sensor and the wiring harness.
                  Finding a friend with an eta where you can swap individual components one at a time until the problem is isolated would be another option, but a little harder to accomplish
                  Can you post a few detailed pictures of the engine bay and odd/missing components?
                  101
                  The E30 collection:
                  1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                  1987 325is - Delphin / Black Sport (son #3's)
                  1987 325i Convertible - Triple Black
                  1989 325iX Coupe - Diamondschwarz / Black Comfort
                  1990 325iX Coupe - Sterling Silver / Grey Sport
                  1981 Fiat 124 Spider 2000 - Green / Tan
                  1998 Volvo V70 GLT - White / Tan
                  1998 Volvo S70 T5 manual - White / Taupe
                  2001 Ford Windstar - Silver / Grey (parts hauler)
                  2006 Lexus GX470 - White / Tan (tow rig)
