coolant leak at block heater
  • bluebenz
    • Apr 2015
    • 36
    Hi,
    After dooing a coolant flush (and timing belt+water pump replacement) on my new to me 1987 325ic my mechanic informed me that there is a coolant leak where the block heater fits.
    Since this will only be a summer/weekend car I dont need a block heater. Where can I find a plug to fix this leak?
    Thank you for your help!
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    Welcome! I assume he's talking about the throttle body heater, which can be bipassed with a small double male hose barb connector. See if your mechanic could do this for you.
    Sent from my moto g(6) using Tapatalk
    (OO=[][]=OO) For Life
    • bluebenz
      • Apr 2015
      • 36
      No, it's not the throttle body heater, it's the electric heating element in the cylinder block connected through a power cord that come's out through the car's grille. Quite common here in Canada, probably not in the US though.
      One solution would be to replace it with a new block heater (which I dont need) but if we could remove the block heater and plug the block that would be perfect (and cheaper!). But I am not sure where to find the plug (or the block heater for that matter).
      • jeffnhiscars
        • Jun 2011
        • 6011
        You just need a new freeze plug which I'm pretty sure a dealer will sell you for not that much. If you can get the specs for it then the range of suppliers increases. Use some Permatex 2 ( non hardening) around the edges
        Alice the Time Capsule
        • bluebenz
          • Apr 2015
          • 36
          Thank you! I am hoping the plugs are still available from dealer!
          • jeffnhiscars
            • Jun 2011
            • 6011
            Get the PN from realoem.com then search.
