731 vs 885 oil in-flow
  • Lugnuts
    • Oct 2014
    • 136
    What's the purpose of the small pair of holes between each combustion chamber on an 885 head, which aren't present on a 731 head? These mate with the same holes in the block...
    Just had a bit of a eureka moment, realising the in-flow from the block is actually through the single, larger central bolt hole (right?)
    Looking to buy a 731 and was concerned about block compatibility. Everything I've read suggests they're bolt-on compatible...
  • digger
    • Nov 2005
    • 6162
    Oil comes up a bolt hole yes. Those little holes are not for oil. Compability yes
