After my well overstretched accelerator throttle cable snapping and being replaced with a new one my E30 Baur now seems to have a crazy amount of acceleration at kickdown and the revs are reaching redline 7k + in no time at all...:devil:
This gives the whole car a radically different performance to what I have experienced with it before and is incredibly fun...but I’m wondering whether it is actually viable and safe for it to run like this without the possibility of causing some major damage??Is it meant to run like this?
The car is a 84 pre facelift 320i,and I am thinking that the new throttle cable may be tensioned too tight and is allowing the throttle to open up further than is intended to by not reaching the crude stop behind the throttle peddle.The throttle is however currently tensioned so that the throttle does not move at all until at least a fair bit of pressure is put on the pedal.
Am I correct in thinking that the second cable attached to the throttle is going to the transmission and triggers the correct gear depending on the throttle position?if this is the case could it be that this cable is no longer ‘in sync’ and that the kickdown downshift happens at slightly the incorrect time?
Any input from anyone far more knowledgable than me would be greatly appreciated...
