RHD ITB and MAF?
  • Nader393
    • Dec 2015
    • 408
    RHD ITB and MAF?
    Heh, it's like a different language. Knowing these abbreviations means I've been hanging around here way too long.
    Anyway, now that RHD ITB setups use an air box, could a MAF sensor between the filter and air box inlet work as planned? If I switch to ITBs, I'd like to salvage my existing Miller MAF and ECU+chip.
    '91 325i
  • digger
    • Nov 2005
    • 6206
    yes, can be done. you need to make a spacer to fit the OE throttle switch so it clears the thermostat housing. i have a mate using MAF and WAR.
    id look for a plug and play ECU with a "proper" TPS though if possible
