Bleeding an m20
  • PROJECT_E34
    • Dec 2018
    • 5
    Bleeding an m20
    Hi guys having a bit of a strange issue since replacing the headgasket on my e34 m20b25..
    Iv followed the numerous bleeding threads..
    Jacked the front of the car up
    3mm hole in the thermostat
    Filled all the pipes up manualy
    Etc etc
    The temperature is behaving however the blower inside the car is playing games.
    So all pipes are heating up (i assume thermostat is opening)
    However i only get hot air at the windscreen setting not out the dash vents or foot vents. Any ideas? Or do i need to continue bleeding it some more?
    Any helps appreciated
  • uturn
    • Dec 2010
    • 1008
    https://www.realoem.com/bmw/enUS/sho...diagId=64_0114
    Part #15 was my issue when I had an e34.
    • PROJECT_E34
      • Dec 2018
      • 5
      Thank you sir! Truelly cant thank this forum enough!
      For anyone experiancing a similar issue the dude above seems to be spot on, although i will feel if the 2 outlet pipes are hot. The valve gets clogged with crap (which i had loads in my system) so no doubt this is the issue.
      Cleaning the valve
