Valve cover brand preference?
  • LateFan
    • May 2013
    • 4436
    Which valve cover gasket are we liking this year?
    febi
    VICTOR REINZ
    OEM for $43 ?!
    rein
    others?
    And what are the D end plugs called? Not showing up in a valve cover search for some reason.
    Thanks.
  • LateFan
    • May 2013
    • 4436
    duh....rocker shaft plugs. Elring?
    • digger
      • Nov 2005
      • 6199
      i use OE as i like the textured /embossed surface that conforms well. i use a very thin coat of non hardening aviation cement stuff for extra security
      • EyExR
        • Jan 2011
        • 959
        I've given up on valve cover gaskets. They have all failed me. I put the end plugs in but use The Right Stuff gasket maker in place of a gasket.
        My 325iX DIY Threads:
        Front Wheel Bearing Replacement
        325iX Rear Subframe Bushings and MUCH more w/pics!
        325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        • LateFan
          • May 2013
          • 4436
          Are you guys finding issues with air leaks?
          digger - which surface do you put it on? How hard to scrape off each time?
          Thanks -
          • digger
            • Nov 2005
            • 6199
            i don't know about air leaks via the gasket but mine vents to atmosphere via the breather...
            i apply to all 4 surfaces with the little brush and rub it in spread it around with fingers (rubber gloves) it basically wipes off with carby cleaner and elbow grease but its not hard, thats why i dont use anything else the cleanup is too painful
            • digger
              • Nov 2005
              • 6199
              without a gasket you wanna be careful the cover doesn't get hung up on the rocker shaft lock, it can also happen with a gasket of the lock is not pressed home 100% correctly
