oil leakage with new head gasket
  • scipio84
    • Aug 2016
    • 19
    hello everyone.
    Few months ago I changed the head gasket of my M20, it's a 2.0 liters.
    I took the head to machining to clean it up, worked by myself the engine block, put a new head gasket (Reinz) and new bolts (Reinz as well).
    Now, after few miles (perhaps 400, 500), I noted the outer surface is oily on the front right corner.
    What can be the reason?
    I'm thinking I need to replace the bolts... but is it necessary? Can I do it without moving the head?
  • e30austin
    • 15382
    Retorque the head bolts and see if that improves it any. The VR gaskets are known to be garbage. If your leak persists, then my advice to you would be to install a Goetze or Elring gasket.
    • nrubenstein
      • 3148
      VR gaskets frequently leak there.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • scipio84
        • Aug 2016
        • 19
        Unfortunately Goetze and Erling appears to be all out of stock, only VR was available at that time (perhaps Ajusa was, but I'm not so confident).
        To retorque: Do I have simply to verify the final torque in the correct sequence?
        The point is: what should be the final torque? Tightening is torque+1/4 turn+1/4 turn.
        • e30austin
          • 15382
          Follow the order of which they get tightened. See if you can get another 1/8-1/4 turn out of them. They shouldn't go much more than that.
          • digger
            • Nov 2005
            • 6181
            If you end up changing the HG just go OE they are the best
            • Melon
              • Mar 2018
              • 1311
              x2
              OEM here, with oem torx bolts, no leaking.
              I do things.
