325i starts but then stalls
  • AlexSutherland
    • Apr 2017
    • 41
    I tried starting my car today and as soon as the car starts, it stalls. If I give it a little gas, it immediately jumps to 3000 rpm and stays there if I barely keep the gas pedal pushed down. Once I let go it drops and stalls. Today, my car was rattling under the car which feels to be the exhaust. Could the stalling issue be related to an exhaust leak?? I highly doubt it but I'm not fully sure. I'd assume it's fuel related. Any ideas would be greatly appreciated!
  • IRON-E
    • 16548
    Failed fuel pump
    @IRON-E30 aka Edwin:D
    • tomstin
      • Mar 2015
      • 568
      I'm thinking more electrical, I would check the throttle position switch, then the Idle Control Valve (and related hoses).
      2004 525i Manual - 1985 325E Coupe Manual
      • 325e '87
        • May 2017
        • 503
        Doesn’t the engine idle at 3000rpm if you unplug the idle control valve?
        My son has the 1987 325e, 2 door, 5speed
        I daily the 1989 325i, 4 door, 5speed
        • AlexSutherland
          • Apr 2017
          • 41
          Originally posted by IRON-E
          Failed fuel pump
          Thanks IRON-E, you're probably right from how the car acts, I'll check the fuel pump later today. Really appreciate it!
          • AlexSutherland
            • Apr 2017
            • 41
            I wouldn't have thought about the throttle position switch, I'll look into both the TPS and ICV. Thanks for the advice!
            • AlexSutherland
              • Apr 2017
              • 41
              That was literally the issue. idk how but my ICV popped out from the throttle body connection
              • AlexSutherland
                • Apr 2017
                • 41
                Thanks Tomstin, it ended up being the ICV. Somehow it was disconnected from the throttle body.
