What advice do you have for a first timer swapping in a 5-speed?
  • jgilber0
    • Nov 2016
    • 457
    Getting ready for the big 5-speed swap next week! Parts are nearly all delivered, new clutch, new hydraulics, new bushings, newly machined flywheel, rebuilt driveshaft, etc...
    I've read nearly all the postings on this topic on R3V and elsewhere and I feel like we are mostly ready, but there is always something that bites you in the ass.
    If you have done this job already, what is the one most important piece of advice you have for my mechanic and me?
    Anything you have to share would be deeply appreciated. Thank you in advance.
    Here are a few pics:
    More of my photos on flickr here: https://www.flickr.com/gp/jgilber0/ev577G
    Jon (OO=[][]=OO)
    1992 325ic white, stock with a 5-speed swap
    Palm Beach County
  • e30davie
    • Apr 2016
    • 1788
    I personally found the most difficult part of the job removing the old auto. the auto box is way bigger than the manual box and difficult to get your hands around.
    those top two bolts on the bell housing best way i have found to get them is like 3ft of socket extensions and get at them from behind and across the top of the gearbox. Once i realised this they are easy to remove.
    • jgilber0
      • Nov 2016
      • 457
      Excellent- thank you Davie! What else, guys?
      Jon (OO=[][]=OO)
      Palm Beach County
      • Poorhouse
        • Nov 2016
        • 497
        In for tips as well.
        I've got the engine out so removing the automatic was easy.
        You doing a short shifter?
        1991 318iC
        1989 325i Field Rescue
        • ButtJuice
          • Dec 2009
          • 2609
          Don’t run a used starter like I did, get a new one. Replacing a starter is a b*tch when everything is installed. Also, if you ever plan on upgrading your shifter items the best time to do it is now. Dual sheer selector rod (DSSR), shorter shift kit, bushing replacement, etc.
          1991 318is - Sold
          1986 325 - Sold
          Instagram - Lamoursum
          • Joegreen02
            • Dec 2018
            • 80
            Lock tight the flywheel bolts. Rear main seal while you're there. Input shaft seal on the trans. Pilot bearing should go without saying.. Brass pivot pin on the trans. Find a starter that is threaded if you can. Guibo.
            • Beamerboi
              • Jun 2018
              • 416
              That pedal assembly too hard to get I just swap bolt instead on the existing one.
              • jgilber0
                • Nov 2016
                • 457
                Just stock, nothing fancy. She’s a cruiser.
                Jon (OO=[][]=OO)
                Palm Beach County
                • jgilber0
                  • Nov 2016
                  • 457
                  I’m trying to keep cost at an absolute minimum, so sticking with stock shifter. We are replacing all the bushings, the cup, etc...
                  My starter is working great, any reason to replace it other than concern about future failure? Is the same starter used with manuals? Nothing I’ve read seems to indicate that it needs to come out.
                  Thank you for your help!
                  Jon (OO=[][]=OO)
                  Palm Beach County
                  • jgilber0
                    • Nov 2016
                    • 457
                    Totally agree on the rear main seal and input shaft seal. We have a new pilot bearing going in, and I’m using brand new OEM flywheel bolts with Loctite on them already.
                    Brass pivot pin: Really necessary? Do the plastic pivot pins really wear out with normal driving? I’m only driving the car 3 or 4K a year.
                    Thanks Joe!
                    Jon (OO=[][]=OO)
                    Palm Beach County
                    • jgilber0
                      • Nov 2016
                      • 457
                      Will try that - thanks. Looks difficult to swap the whole airbag pedal assembly.
                      Jon (OO=[][]=OO)
                      Palm Beach County
                      • e30davie
                        • Apr 2016
                        • 1788
                        Don't replace a rear main that isn't leaking.
                        • gath
                          • 577
                          Elaborate please.
                          • jgilber0
                            • Nov 2016
                            • 457
                            Originally posted by gath
                            Elaborate please.
                            Why is that, please? Likely to mess it up?
                            Jon (OO=[][]=OO)
                            Palm Beach County
                            • Poorhouse
                              • Nov 2016
                              • 497
                              Thanks Joe!
                              I've read they break very easily and frequently. I got a brass one for $15 iirc.
                              1991 318iC
