Hello, I swapped my 84 325e to Motronic 1.3 with new head, injectors, harness from a late model car, and 153 ECU from an 87. Also modified the harness by shortening the wires (cut, crimp) for the diagnostic plug to install it into the M3 wire harness cover.
Been struggling with a no spark condition, followed the troubleshooting list that's been posted by jlevie. Verified fuel pump, injectors work. Main relay clicks over. Everything checks out except for "Also verify that from DME pin 1 to ground is an open circuit." I have continuity to ground instead. How would I go about resolving this? I read a pinout for the diagnostic plug wires that I shortened and found that the big black wire to pin 1 is for the ignition coil, does this also lead to DME 1? I remember it had a a shielding core around it and was a pain to reconnect, is it possible that I'm somehow grounding out the pin there?
