e30 m20 does not start even with a full battery.
  • reallyloudsandwich
    • Feb 2019
    • 3
    Hey guys so i want your opinions/advice. About half a year ago, my starter went and decided to tuck it away for the winter time. Now that's spring, it's time to bring it out again. Tried cranking the car with the original starter on a fully charged battery, just a click. Headlights, as well as all the other electronics, don't dim at all. Changed the starter last night and this time, when i turn the key, i hear multiple clicks as if the battery is dead. Tried a different battery as well as hooked the jumper cables up to the car via my daily... same thing happens. My friend that has had a good amount of experience with e30's told me it's the engine harness because it seems like all of the electronics work perfectly fine except the starter isn't getting enough power. What do you guys think? Thanks!
  • IRON-E
    • 16548
    Check your crank sensor or just replace it.
    @IRON-E30 aka Edwin:D
    • e30davie
      • Apr 2016
      • 1788
      16,253 posts and its pretty obvious you didn't read the post.
      Clicking starter motor to me suggest that its not wired properly or a loose connection. jsut as your friend suggests. I would be checking to make sure your engine grounds are all in good order. Check your battery terminals are in good condition and are tight. and the cables to your starter are in good shape. A quick scuff up on terminals with a wire brush can work wonders.
      • tomstin
        • Mar 2015
        • 570
        First, verify the battery connections are good. Next, the battery cable connection on the firewall above the battery tray (check voltage there). Then the thick ground cable below the alternator near the base of the oil level check tube. Make sure all those are good. Are the connections to the starter correct?
        If you're still stuck, take the starter out and bench test it. Won't be the first time a new defective made it out of the plant.
        "decided to tuck it away" Any signs of rodents that may have chewed on some wires?
        2004 525i Manual - 1985 325E Coupe Manual
        • IRON-E
          • 16548
          caught tldr; and CPS broeh.... it's been a running joke on r3v.
          • dnguyen1963
            • Nov 2011
            • 2651
            So true and I am guilty of this too.
            • nrubenstein
              • 3148
              A starter click means inadequate power to the starter. So grounds and 12V supply are what you need to look at first. I’d probably start with the engine ground strap.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
