M20 can't get the temp. Needle in the middle
  • ADEN
    • 620
    I want to be direct.....
    320i 89
    Needle bearly reach 1/4 noon time sometimes in traffic reach between 1/4 & 1/2 as soon as i hit the gas it drops to 1/4 and if i kept driving i goes between 1/4 and the blue line.it's a nightmare on cold mornings or in highways at night.
    Bot Tested thermostat 87c (Mercedes Benz oem type) where i live bmw oem stuff are expensive and hard to come by.
    Deleted the heater core with the block both pipes method.
    Only thing i have as a suspect is the fan cluch engaging all time.
    Another thing i suspect is the return hole in the expansion is returning upon any slight revs even when the engine cold.
    Is that really a cause of my overcooling problem?
    PROBLEM SOLVED
    I forgot to install t-stat seal some coolant were escaping thanks to all of you
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5493
    Are you positive the thermostat is closing?
    I would start off by replacing the thermostat with an 80*c one and see what happens.
    If you really thing the therm is working, I would get a laser thermometer to see if the gauge is even reading accurately
    • rturbo 930
      • Dec 2005
      • 2615
      Sounds normal to me. My temp gauge never makes it to the halfway mark.
      • Tisoc
        • Jul 2011
        • 249
        Mines the same. I don’t worry about it.
        • ADEN
          • 620
          I will get 80c oem t-stat and see .
          About the gauge being accurate the car cold knocking sound is there most of the time as long as the needle doesn't pass 1/4.that's why i am not suspecting the temp reading.
          • ADEN
            • 620
            Thanks man but mine didn't even stay on 1/4 line.it is below it most of the time puls suffering bad mpg. My engine is wearing fast i believe.
            • cheffy30
              • Sep 2016
              • 1159
              mine never goes to the middle. idling for 15 minutes and maybe it will move up half way to the middle. start moving and it drops down. always just a squeak over the blue.
              my 2c
              '90 325i sedan daily driven
              '85 325e coupe also a daily
              • LJ851
                • 7918
                An E30 with a stock thermostat should sit very close to the middle of the gauge, that’s where the thermostat opens. Slightly above 1/2 way on the gauge is where the fan clutch kicks on so the needle stays very steady at the middle of the gauge in most conditions.
                If you have a thermostat opening sooner, the gauge will move around a lot more since there is a wider gap between the thermostat and fan clutch.
                Lorin
                The M30 is God's engine.
                • ADEN
                  • 620
                  That's what my car used to do. Please provide some suggestions....
                  • LJ851
                    • 7918
                    The thermostat controls the base temp, i would put in an OE or OEM brand thermostat with a factory opening temperature.
                    Lorin
                    • ADEN
                      • 620
                      Thanks man
