Misfire and loud valves/knocking sound
  • angelfire
    • Nov 2018
    • 32
    Help! I have adjusted the valves several times on my m20 at the eccentric and the cam. My valve noise is still super loud and it has quite a prominent misfire at idle. I have tried 0.010 and 0.008 clearances and nothing really helps. I have 20w-50 oil and the car has about 212k miles. Not sure if the head has been rebuilt before. I don’t want to drive it the way it is but I really don’t want to throw parts at it if it can be fixed without any. Any ideas? Also has a knocking sound when you rev the engine. I wish I could post a video but I’m not sure how lol
  • hotsaucewizard
    • Sep 2013
    • 93
    have you checked the timing? i had a loud knocking/ticking from the top end that i couldn't make go away through valve adjustments... turned out the timing jumped 1 tooth forward. sounded like this:
    before valve adjustment:
    after:
    • jbontke
      • Mar 2019
      • 448
      Just out of curiosity, are you sure you were using the correct feeler gauge and didnt get the wrong one by accident? I say this as I have a set of feeler gauges that are metric/std and its easy to get them mixed up.
      • jeffnhiscars
        • Jun 2011
        • 6010
        With that mileage and an unknown history you could easily have worn eccentrics, cam and or rocker faces any or all of which could cause clearance issues.
        Alice the Time Capsule
