cold idle problem...
  • MrK
    • Jan 2006
    • 709
    Hey guys,
    I've been having this nagging problem for a while, and I'd like some second opinions before I go messing about under the hood.
    My car idles REAL low (around 300rpm) when I start it in the morning, and slowly rises as it warms up, and reaches a more typical 800rpm when it's ready to run. Is that NORMAL? I'm thinking my coolant temp sensor isn't working like it should. Am I right?
    The car is a euro 1990 2.7 stroker if that helps any.
    This is your M20 on steroids:
    • 34844
    no, it should idle at around 1000rpm when it is cold, and slow down to ~600-800 when it warms up. definitely test your coolant temp sensor, it's pretty easy to check on with a multimeter.
    • MrK
      • Jan 2006
      • 709
      Coolant temp sensor checks out fine, anything else I can check on?
