M20 Short Block
  • ZiMMie
    • Jun 2004
    • 968
    M20 Short Block
    How much does it weight, and does anyone know if it will fit in the back of an e30. Jst the block without any harness/accessories and Head?
    www.stancefactory.com
  • pdx 528e
    • Jun 2006
    • 33
    It should fit if its just a block. I would guess it weighs about 175 with the crank shaft, rods, and pistons.
    • O 16581 72452 5
      • 1066
      Should be light enough for two guys to carry if that's what you're wondering.
      • digger
        • Nov 2005
        • 6196
        block is 45 kg bare
        crank is around 20-25kg
        it is possible to carry a block, crank, rods, pistons, head, timing covers, sump, harmonic balancer, pulleys, flywheel, water pump, oil pump etc with 2 people.
        the block assembled with crank, rods and pistons, int shaft easily fits in the boot and is easily lifted in and out unless you are a girl.
