I feel like a retard for asking, i have an e and an i, what frankenstein can i make?
  • O 16581 72452 5
    • 1066
    Like the title says, i picked up an e for a parts car, not really sure what condition the motor is in, but mine's starting to puff some oil. Figure around Spring it's time to rebuild, what options do i have with these two engines in to getting some more power with my rebuild?
    Appologies for so many threads on this e car i bought, brainstorming what to do with it.
  • REVHARD05
    • Sep 2005
    • 250
    2.7I or 3.0l m20
    • O 16581 72452 5
      • 1066
      Great, soooo, what parts swap over? :P Is it as simple as bolting on the head to the e block, or do i need to swap the e internals to the i block?
      From my reading something about only the s-eta and i motors having interchangeable parts, other say an eta block and i block has interchangable parts.
        • 34839
        Originally posted by REVHARD05
        2.7I or 3.0l m20
        you can't get 3.0l with an e bottom end. the most you can get is 2823cc with an 86mm bore.
        • etxxz
          • Feb 2006
          • 2085
          i think his thread is mostly about what is the simplest stroker that he can make...like swapping the eta crank, rods and pistons into the I car/management and have a cheap rebuilt stroker engine... ^^ i'm really not informed and looking for info myself so someone who knows please correct or clarify.
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • O 16581 72452 5
            • 1066
            Basically.
            Are the actual blocks any different, or is it just the internals?
            • PiercedE30
              • Apr 2005
              • 4220
              internals
              My 2.9L Build!
              • O 16581 72452 5
                • 1066
                *rubs chin*
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  Slap the m20b25 head on the b27 block and you have a low compression (around 7.9-8.0:1 ish) 2.7l stroker. Perfect for a turbo setup. You can mill the head a little to get compression back but then you need an adjustable cam gear to gain back the timing you lost by doing that.
                  Will
                  RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                  Welcome e30 (brilliantrot '90 325is) 12/23/06
                  DaveCN = Old Man
                  My signature picture was taken by ME! Not by anyone else!
                  If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                  • O 16581 72452 5
                    • 1066
                    A little too low for my forced induction plans. I know about the adjustable cam gear, i had a milled head on a Honda milled so much i just corrected it by putting the timing off one tooth from stock. XD
                    • dmoney(AB)
                      • 1372
                      Will
                      does anyone offer an adjustable cam gear? i have yet to see one. :p
                      mtech1/2jzgte/r154/275tire
                      function>form
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        $250
                        $275
                        Those are the only ones that I know of off the top of my head.
                        Will
                        DaveCN = Old Man
                        • Skafrog
                          • 1732
                          Will, why are you on Locost build forums?
                          NASA MidSouth TT Director / GTS2 #018
                          Mods: Coastal PS Fluid, 10w40 Oil
                          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                          • PeaveyBassist
                            • Sep 2004
                            • 3511
                            get on aim fag.
                            Will
                            DaveCN = Old Man
                            • golde30
                              • 11464
                              sounds like a perfect compression for an f/i motor to me. slap on a turbo+ IC and boost like 12psi. would make for a more reliable turbo car(less blow HG).
                              IG: @Baye30
