valve help
  • jrdn223
    • Jun 2004
    • 138
    valve help
    just got my head reinstalled after gettin it back from the machine shop, all new seals and gaskets put on. my mechanic said he set the valves to bmw factory standards but they are still producing a VERY loud ticking noise. my question is what should the valves be set at if i have a shrick 272 cam and bigger injectors and whatnot for the 2.7 stroker. it pulls pretty hard right now but i need get the valves right, hopefully make even more of a difference
  • mrsleeve
    • Mar 2005
    • 16386
    Well I dont know for sure but in my experience bigger injectors do tick more. You might be hearing injector noise.
    Originally posted by Fusion
    William Pitt-
    • e30_325es
      • 1249
      Were the valves set w/ the head off the engine? I've found that they end up being too tight that way.
        • 34835
        did you check for valve clearance (between the piston and valve)?
        • cthulu703
          • Oct 2004
          • 288
          Is your cam a regrind? If it is a performance cam, make sure it uses the stock base circle.
          • etxxz
            • Feb 2006
            • 2085
            if you've already done a valve adjustment then its probably your injectors. mine ticked (still do) so i did a valve adjustment and it didnt get better so i did it a second time just to make sure and maybe re-adjusted one valve and nothing so i guess just clean your injectors. its pretty easy and straightforward to get to them.
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
