Just my luck...
  • e30 gangsta
    • 3877
    Just my luck...
    So after snapping a rocker i decided to do a full top end rebuild. Ok all is well head is going in with new goodies ray ray ra. So im @ the headbolts tightening them down to 80 ft lbs like is says on e30tech turbo faq. This car is not turbo but i just wanted to use these headbolts. I get to the 2nd to last one @ 70 lb ft of torque and booom snapped bolt. Its deep in the block and im pissed as fuck. I have no idea how im going to get that out. And if it happens again im scarred that i might strip the bolt and then wont be able to take it out. Fuck why me??
  • trashcop 80s 80s
    • Jun 2004
    • 1130
    80 ft/lbs seems like overkill, I thought I heard those bolts (metric blues right?) were fine at 60 ft/lbs.
    Did you wipe any oil on the bolts? If you put too much oil on them it could cause them to snap, as oil is not very compressible, so if there is any dripping into the bottom of the bolt hole it could put stress on the bolt.
    • WillisE30
      • Jan 2007
      • 831
      Oil on the bolts usually won't cause them to snap, however if there's oil or coolant in the holes you run a very serious risk of cracking the block or breaking the bolt.
      sigpicFormer professional wrench thrower.
      Current:
      1988 325is S52
      Former:
      2008 Sparkling Graphite M3 Sedan(victim of home ownership)
      1988 M5
      1996 328is
      • BDSax
        Junkyard King
        • Mar 2006
        • 3593
        damn.............. i have a motor for you
        NEED SOME VINYL STICKERS???
        • erik325i
          • Jan 2005
          • 3567
          What he said^^
          Did you clean all of the oil/coolant from the bolt holes before installing the head?
          -Erik
          • Joe318is
            • Sep 2005
            • 6451
            EZ Outs
            Originally posted by vlad
              • 34837
              this is why you stick to the stock headbolts. they are just fine for an N/A motor :p
              good luck getting that bitch out of there..
              • e30 gangsta
                • 3877
                yeah all preped and clean etc etc etc. I did everything correctly bitch just snapped. Ah fuck for real nando ima use stock headbolts ima torque that shit to like 50 then 60 then 70 then 80 over 4 nights hopefully they wont snap lol.
                • erik325i
                  • Jan 2005
                  • 3567
                  Why are you not torquing the headbolts to spec? What's special about 80 ft/lb?
                  -Erik
                  • Erick
                    Official R3V Drifter
                    • 11169
                    Have you ever done a compression test on that motor by any chance?
                    ..::Support FullOpp::..
                    FullOpp Stickers for sale!
                    Feedback Thread
                    • e30 gangsta
                      • 3877
                      how much u want for it billy i can always use another m20.
                        • 34837
                        you don't want to do that... the stock headbolts are torque to yield. i think it's 40ft-lbs and then 90 degrees of rotation.. the procedure is in the bentley tho.
                        • Mr Deagle
                          • 1121
                          Fuck why me??
                          because you are stupid for reving ur shit to 7100, its called VALVE FLOAT that shit breaks rockers
                          get some ARP's and you can torque that to 80
                          dont torque the stock headbolts to 80 ft lbs, they are stretch bolts
                          if you want to rev to 7100 agian, get some schrick 064 springs
                          • backtrail69
                            • Jul 2005
                            • 4471
                            My headbolts are torqued to 80 with no problems at all, but I have a stock HG and Metric blues and turbo... I would run stock head bolts all the time if I was NA. No reason to run any thing else.
                            :: PNW Crew ::
                            '87 325 4dr, '74 2002
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3593
                              shut up waffleswaffleswaffleswaffleswaffleswaffles, nobody likes you.
