You Think I Need a Valve Job??
  • SandyEggoE30Girl
    Wencher
    • Feb 2007
    • 318
    My car was kinda running like sh--, so I went down and bought some new spark plugs, rotor, and cap, and this is what I found when I took out the plugs:( The plugs are laid out in the first picture as if the very right is towards the front of the car.
    I don't like the fact there is electrode floting around the chamber???
    • 34847
    I don't know about a valve job.. those plugs are pretty fried. there is a chunk missing out of #2, which is very bad. they all look like they have been running really lean or detonating.
    • backtrail69
      • Jul 2005
      • 4471
      Put some new plugs in and maybe a fuel filter and some injector cleaner through it, also maybe some premium gas. Then report back in a little while.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • SandyEggoE30Girl
        Wencher
        • Feb 2007
        • 318
        two & three are pretty much oil fouled too. OH! and I ALWAYS use 91 octane in my car.
          With #1 on the right... 1-3 look sort of okay and 4-6 look like they've been running lean. Things to check would include the possibility of intake leaks, bad AFM, or low fuel pressure. And if it has been more than 10K since the last valve adjustment that should be done.
          • SandyEggoE30Girl
            Wencher
            • Feb 2007
            • 318
            My bad! 4 & 5 look oil fouled!
              • 34847
              they do but notice the big chunk missing out of one of them.. that isn't caused by oil. thats why I think you have a lean/dentonation problem.
              • strad
                • Jan 2007
                • 241
                When I pulled the plugs from my new-to-me vert, they looked about like that, but,
                a: they had been in there for 55,000 miles and
                b: there was a sizeable hole in the intake boot for an unknown period of time before I bought the car (running lean).
                Replaced plugs, and replaced air boot, and now plugs look normal.
                The current fleet:
                1992 325ic: 148k-171k miles
                1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                • StereoInstaller1
                  GAS
                  • 22679
                  I think it is time for an injector cleaning!
                  I use RC Engineering.
                  Buy a spare set, or better still, find a set of 4 pintle 17.5lb to swap in after you have them cleaned.
                  Luke
                  Closing SOON!
                  Thanks for 10 years of fun!
