hope that got some attention....
I have a new ICV coming in the mail today (hopefully it will arrive today) from BLUNT... Maybe that will solve the problem.
When the motor is cold it cuts out, misses, bucks, idles low and is generally fcuked up. When it warms up it gets better but not a whole lot better. These problems recently started shortly after the purchase of the car so I'm not sure if they were already there or if I may have done something to cause this. Either way it's so bad the car is barely drivable and almost dangerous because of how it cuts out and stalls.
Recently I have replaced/done: Valves, plugs, wires, cap, rotor, injectors cleaned & replaced seals, BavAuto Adj FPR, intake hoses & TB cleaned and set TPS, MAF cleaned and tested, running 91 octane fuel, new fuel filter, air filter, new 02 sensor.... possibly more.
So when the car is cold I can hear something sucking like a vaccum opening and closing and the car bucks and stalls like a mo-fo when cold. It's really bad - barely drivable. It's like something is shorting and the motor dies. You'll be pulling away from a light in first under load the the car will totally crap out and die. if you are lucky it'll keep going and power through but not always. Idle is about 500rpm. Like I said I'm going to replace my ICV today/tomorrow when it arrives but what else could this be?
I don't know these cars that well and knowing that the TPS and MAF are good as well as the intake and fuel delivery/ignition... I just can't think of anything else outside the ECU or maybe chip???
Any help would be much appreciated. I have to drive for Easter this weekend and I really want this problem solved before we leave.
