My ETA head has scratches in it, will it seal right???
  • vic_325
    • 264
    So the t-belt broke on my ETA, and i bought a used head for it, but i dont know if this head will be good, on the mating face where it touches the head gasket there are alot of scratches that are very visible, but it doesnt catch if i run my fingernail over them. im worried that it wont seal properly if i put it on like that. ill try to get some pics of the scratches.
    would any type of scratches affect how well it seals? could it be resurfaced at a machine shop?
    any advice is good.
    Thanks, Victor.
    • 34839
    why not have it surfaced? it shouldn't cost too much. I think they can do it with the head still assembled. just make sure it's clean before you put it on.
    • vic_325
      • 264
      would it affect the compression at all?
        • 34839
        probably not, but you might have coolant and oil leaks up the kazoo.. definitely not worth taking the chance!
        • Mr Deagle
          • 1121
          if you had it milled, it would increase the compression slightly, but that would give you mo powah!
          • vic_325
            • 264
            i was telling my dad that it can be resurfaced with the head assembled. but he dont beleive it. how does the machine shop resurface it with the valves still in?
            • Brew
              • 3060
              You should always have a cylinder head resurfaced if its going onto a non-original bottom-end. Also make sure to check the block for trueness with a straight edge.
              '91 318is
              • vic_325
                • 264
                i took the head to a machinist, so he can take a look at it, and he said that the scratches wont be a problem, he also checked for warpage and it was straight. so i think im just gona run it.
                • MikeE30325i
                  • 2356
                  better to be safe than sorry.
                  • backtrail69
                    • Jul 2005
                    • 4471
                    Should be fine if it checks out with a knowledgeable machinist.
                    :: PNW Crew ::
                    '87 325 4dr, '74 2002
                    • vic_325
                      • 264
                      ya, well i took it apart anyways to get the valves reseated.
                      i also want to throw in some dual vavle springs, but do they go in fine?
                      • NC325iC
                        • Mar 2004
                        • 6565
                        may as well build it up as an i head
                        • vic_325
                          • 264
                          ya i could've put in the i cam, but i read it wouldnt run good unless i switch to i ecu and harness
                          • helikon06
                            • Feb 2007
                            • 16
                            the vavle springs should fit fine, i mean you get it aparts and they don't fit put the other ones back on, no harm no foul...
                            • NomadE30
                              • Mar 2007
                              • 236
                              put in the I cam have the head ported and change over your intake system and exhuast then call up mark d and have him make a custom chip
