M50 injectors a success!
    • 37833
    Installed my "new to me" M50 injectors a little while ago along with all new o-rings. The car seems to run a lot smoother and pulls happily.
    Now it's time to give the M30 AFM a try. When I did a test run with the M30 AFM before the injectors the car ran like shit.
    Grover Beach, California
    BimmerHeads.com
  • nickmcc92
    • Dec 2012
    • 442
    I too have m50 injectors in my m20b25 and am wondering if the m30 afm made a difference?
    • dougie30
      • Apr 2012
      • 1708
      will the m30 maf and m50 injectors work well with my bmp chip?
      M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
      • Pocket Chant
        • Mar 2012
        • 403
        M30 AFM actually did provide a slight boost for me on the second try. First time the car was mostly stock, second time I had a free-flow exhaust system as well M50 injectors and it gave the car a noticable low-end kick.
        1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
        MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
        Originally posted by MclubSport
        Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
        Horrible with responding to PMs, I'm so sorry.
          • 37833
          Well this thread is almost 6 years old.
          But yes my old car ran great with M50 injectors, M30 AFM, and Turner chip.
          BimmerHeads.com
          • AndrewBird
            The Mad Scientist
            • 11898
            At least the guy searched and found this thread, right?
            • dougie30
              • Apr 2012
              • 1708
              What about a BMP chip? Think it will make a difference?
              • nickmcc92
                • Dec 2012
                • 442
                Thanks NitroRustlerDriver.
                • E30_fiend
                  • Apr 2006
                  • 7348
                  Exactly my thoughts
                  • nickmcc92
                    • Dec 2012
                    • 442
                    Originally posted by E30_fiend
                    Exactly my thoughts
                    I was thinking the same thing.
                    • CR325IS
                      • 514
                      well played.
                      • Alex Mc
                        • 281
                        Since the M50 injectors are a higher flow rate than stock M20 'i' units, does the DME/O2 sensor just sniff out the richness and decrease the pulse width? In other words, you guys are running these injectors with no additional modifications and seeing improvement in operation?
                        I don't really care about more power or whatever, but if there's a smoother idle etc then I'd like to make the change.
                        Current: Brilliantrot '91 318is M20B25
                        Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
                        wamchenry@gmail.com
                        insta: @simple_machines
                        • Q5Quint
                          • Jan 2005
                          • 725
                          old timers checking in.
                          Are m50 injectors 4 pintle?
                          I did a ford 19# plus the big afm on my old ix before the turbo incident and was able to get almost 30mpg on a few trips. Figured the better fuel atomization from new-er 4 pintle injectors plus the wideband o2 leaning it out perfectly was what did it. And driving downhill with the wind behind me.
                          I think I had a wideband on it at the time..... but I cant even remember what I had for breakfast. Either way you will adjust the afm to make the car idle, and then reset your ecu by pulling the battery cable off for 15 min so that the ecu can 'learn' the too-big injectors... ie adjust the stock opening times down a bit so the car runs the correct a/f mix.
                          If you just pop the big boys in you will be idling horribly and running in stinky flood rich city until the computer learns you back straight with the o2 from driving around for a hour or so.
                          • Quinthirty
                            • Mar 2012
                            • 318
                            Yes, M50 injectors are 4-pintle.
