is this a fanclutch problem?
  • ummagawd
    • Jul 2006
    • 144
    trying to get a car smogged
    they need to be able to warm up the cat
    to warm up the cat they usually let it idle for a long while
    well it decided to start to overheat
    i suspect fan clutch?
    and i know for a fact that my thermostat is sticky cuz it takes some time to warm up... and when it does... it doesn't go past the 1/4 mark
  • backtrail69
    • Jul 2005
    • 4471
    I would replace the electric fan switch with one from a e36 318is, thermostat, fan clutch and flush the system. Cooling problems will be history.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • ummagawd
      • Jul 2006
      • 144
      suggestions noted
      thank you sir
      • AndrewBird
        The Mad Scientist
        • 11898
        Were in indoors during the idle time (I.E. - Garage bay)? Could have just not been enough air flow through the radiator.
        Easy way to test if it is the fan clutch is to let the engine warm up, stop the engine and try to spin the fan. If it won't turn/turns the water pump, then it is good. If it spins easily, then it's bad.
        Does it overheat any other time?
          • 34844
          I can idle my car all day long in my garage and it will never go above the 1/2 mark. electric fan conversion FTW!
          • strad
            • Jan 2007
            • 241
            You need to replace that tstat too. If it doesn't go past a quarter it's probably still running cold enriched, which won't look good to the tailpipe sniffer.
            The current fleet:
            1992 325ic: 148k-171k miles
            1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
            1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
            • PeaveyBassist
              • Sep 2004
              • 3511
              True story! I have the e36 m42 (318is) fan switch, stock electric fan, and no engine driven fan. Never gets above half. Ever.
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • Adrian_Visser
                • Jun 2006
                • 2823
                so if your thermostat is sticky it can actually keep the car from ever reachin the 1/2 way mark? it wont just delay it?
                '89 Alpine S52 with goodies
                • backtrail69
                  • Jul 2005
                  • 4471
                  It should just take FOREVER.
                  :: PNW Crew ::
