E to I swap wiring dilemma
  • maniacmatt
    • Feb 2007
    • 483
    Okay, so I am in the middle of the E to I swap on my '84 325e. Now before the swap I contacted MR325 and he told me about the adapter harness he made and the wiring connections necessary. However for his method to work I need and full "I" engine harness, the fusebox plug from the "E" harness, and the chassis plug from an "I" car.
    Here is what I do have. I have the "E" fusebox plug and an "I" engine harness however the engine harness I have is missing the diagnostic plug and the c101 connector. I also have a complete 88 super "E" engine harness and the chassis connector from that same car. Is there anyway I can make this work? Or do I need to find a full "I" harness and chassis connector before I go any further?
    Thanks
    Matt
  • Mr Deagle
    • 1121
    get a full "I" harness
    I originally came up with that method
    edit: Meaning that i shared the info with Matt
    • euroshark
      • Apr 2006
      • 3491
      Holy fucking bullshit dude, now you are claiming to be the first one to put an I harness into an e car?? Jesus, what the fuck have all the other E30 owners been doing all these years?! lol... just lol...
      I put a 635CSi harness in my '84 325e before I even heard about your swap, so I guess that make me the real innovator. Hey everybody!!! Look at me!!! I was the first person to ever put an "i" harness into an eta!!
      • Jscotty
        • Jan 2007
        • 2285
        Well in case you guys wanted to know.. I am the REAL inventor of the Internet.
        • maniacmatt
          • Feb 2007
          • 483
          I'm glad I'm not the only one who felt that he came across that way.
          My most sincere apology to you Mr. Deagle for accidentally giving credit for all your hard work to someone else. I will do everything in my power to ensure that it never happens again. [/sarcasm]
          • JoeMadoo
            • 936
            I have an I harness if you'd like one
            '86 E30
            '05 E53 X5
            '72 Firebird
            '10 Prius
            '03 Tundra
              • 37828
              Deagle meant that he sent me the info I shared with you.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • James Crivellone
                Head Janitor
                • 6301
                You have a few different options. First off you have the ETM right? This makes everything a hell of a lot easier to get this done.
                Option 1, you want an I engine harness and firewall connector, you also need a C104 connector and/or wire taps to provide tachometer and fuel rate (MPG Gauge) function. You also want to buy the little clip that secures the round C101 connector to the firewall.
                Remove the wiring harness from the car, unscrew the fuse box and remove the engine firewall connector, install the new one following the correct pinout available in the ETM. This will provide the most stock looking appearance.
                Option 2, build an adapter. You will want the engine harness connector from the 84, and the firewall connector from the I. You also want an I engine harness. Also pickup the C104 connector.
                Here is a shot of an adapter I built for a customers car. 90I motor in a 84e Chassis.
                You have many options, take your pick =)
                • euroshark
                  • Apr 2006
                  • 3491
                  James, did you follow Mr. Deagle's instructions when you were building that adapter??? I heard that they appeared on stone tablets right before the Ten Commandments!!
                  • James Crivellone
                    Head Janitor
                    • 6301
                    No, I just use the ETM. Over the past few years I have mastered every bloody circuit inside the E30 Chassis.
                    • euroshark
                      • Apr 2006
                      • 3491
                      Edit:
                      • James Crivellone
                        Head Janitor
                        • 6301
                        Edit:
                        ah just got the joke.
                        No I invented everything to do with wiring, damnit.
                        • Mr Deagle
                          • 1121
                          There we go :hitler:
                          • euroshark
                            • Apr 2006
                            • 3491
                            That's not nearly enough to redeem that statement... You are too easy lol...
                            • maniacmatt
                              • Feb 2007
                              • 483
                              I am aware of that. It is just that the way his comment came across that bothered me.
                              Thanks for all the info James and thanks for offer Joe. I have a new I harness and chassis plug on the bus from a wrecker so I am going to go the adapter harness route.
                              I do not have the ETM I am working from a Bentley manual and the help of others. Can someone elaborate on what this c104 connector is and what it does and what I need to do with it. I cannot find any mention of it in the bentley.
