What would you do?
  • speedhop
    • 1509
    What would you do?
    I am looking to put some more ponies under the hood but after countless hours researching...have come to a cross roads.
    Would you....1. Use the existing m20 and seta bottom end for lower compression to turbo?
    or.... 2. swap out the m20 and throw in the m50/2 and save up some cash for the turbo later?
    Goals: 300-400 daily hp
    Hitting peak boost in the middle of the rpm band...no top end stuff :grin:
    what do you think??
    www.ryanwhopkins.com
    • 34844
    3. boosted stock M20B25. how many miles are on your motor?
    a turbo M50 is going to add ~100lbs to the front of your car... it won't matter in a straight line, but it depends on what you want to do with your car.
    you will want standalone either way - the stock ECU is worthless for a turbo. megasquirt is inexpensive, pretty easy to setup and lots of E30 guys are using it so you can get a good base tune to start with.
    • smonkbmw
      Professor
      • Jun 2006
      • 4549
      s50 with all bolt ons will get you close.
      • speedhop
        • 1509
        i want to make sure that i have something to build from instead of throwing in the turbo and having bottom end problems. if i stick with m20 i would definitely want to at least do metric blues and head gasket to make sure i can add more boost later with no problems...i should also add that it will be a street car
        • speedhop
          • 1509
          oh how i wish i could afford an s50...if you would like to donate then i'll do it!
          edit: i'm going to say that i have a budget of about 4g as of now...maybe the market will be nice
          • Mastrcruse
            • Sep 2005
            • 5340
            Theres other things you need but its a start
            • speedhop
              • 1509
              i guess the final setup i could go with is the stroker kit from IE...but I have had no personal experience with this.
              What would one have to do to boost the IE kit...15psi?
              • euroshark
                • Apr 2006
                • 3491
                Get a turbo kit from TCD...
                  LS1 or similar if you want that sort of power on a routine basis, especially it you need it to be mid-range pwer. While you can get there with FI on a 2.5-3L engine, reliabilty will suffer and the power will be at the top end of rpm band.
                  • SnowFiend
                    • May 2007
                    • 106
                    link....?
                    • whiltebeitel
                      • Apr 2007
                      • 2098
                      LS1 FTW. You'll also experience something else mainly foriegn to e30's: gobs of low-rpm torque.
                      '89 325i track sloot
                      '01 530i daily
                      -Enginerd
                      • speedhop
                        • 1509
                        can't we do better than ls1!!!
                        just outa curiosity is where are people puling these ls1's from??
                        are there detailed threads on an ls1 swap? seems kinda...different :loco:
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          General Motors LS and LT Performance Forums, News, and Rumors
                          try the engine conversions forum on BF.c
                          LS1's come from +98 camaros, firebirds and +97 corvettes, as well as trucks, SUVs, GTO's and lots of other things in various forms.
                          The LS1 is one of the best engines right now, definitly the most modifiable, lightweight, and reliable as fcuk.
                          Hey, I go to school in Texas, what the hell do you expect?
                          '01 530i daily
                          -Enginerd
                          • euroshark
                            • Apr 2006
                            • 3491
                            turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
