custom pistons
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    custom pistons
    I need to start sourcing custom pistons for my 2.7i, where do you recommend getting them from?
  • StereoInstaller1
    GAS
    • 22679
    ColdAccord has (had) a set of Mahle with rings for some insanely cheap price, new in the MF box! PM him, otherwise, go MM.
    You gonna do a full rebuild now?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • CorvallisBMW
      • 13039
      Luke
      Ya since the head gasket blew, and I wanted to do my stroker this summer anyway, I am considering just doing it now. i already have a nice head sourced, I just need the bottom end stuff.
      • StereoInstaller1
        GAS
        • 22679
        Want a dead ETA? The one in my Sons car got a forklift in the oil pan, may or may not be good...but free is nice.
        Luke
        Closing SOON!
        • CorvallisBMW
          • 13039
          hmmm that is tempting, and Eugene is not far away. At least if I have a spare block I can build the engine on my own sweet time and just fix my current head gasket problem. I would still need some 'i' rods but I'm sure Joe can help with that.
          • redhatpat
            • Aug 2005
            • 656
            If you're going to make custom pistons, check out Metric Mechanic. I've no idea what they'll charge, but they have experience making non-interference pistons for the M20. As far as I'm concerned, that's what BMW should have done in the first place.
            • CorvallisBMW
              • 13039
              Ya MM makes good pistons, but they are $$$$$$$$. IE has them for much less and they're good quality, and they even have enlarged valve pockets for my hotter cam :) Is there a place that sells a good rebuild kit, i.e. main bearings, gaskets, main bolts, head bolts, etc? I've got sources for all the rotating assembly parts but I need the little bits and pieces now.
              • ja burna
                • Jun 2005
                • 358
                Check out IE, thats where I bought my stuff from.
                "Driving anything else would be uncivilised"
                • Sean
                  • 5793
                  I sourced out all my rebuild parts from various vendors, got mostly everything for my local supplier, Imports Parts Specialists and they pricematched everything with EAP4PARTS.com and BMA.
                  I didn't find any "rebuild kits" anywhere myself...so I just found what I needed and got it all. You have to make sure you get the correct rod and crank bearings...that is, if you plan on putting in new ones?
                  - Sean Hayes
