Aftermarket alternatives to maintenance items..
  • Ahheck01
    • Aug 2004
    • 185
    Just going through all the maintenance items, I'm wondering if there are aftermarket upgrades for the following:
    Thermostat
    Thermostat Housing
    Water Pump
    Oil Filter
    Fuel Filter
    Fuel Pump
    Spark Plugs (Bosch Supers okay?)
    Airbox filter
    and I'm not sure if this is the right section for it, but since I need to replace these, are there smart aftermarket replacements for:
    Driveshaft
    U-Joint
    Thanks!
    -Evan
    1992 525i 5speed: Sold :: 1996 328i 5speed: Sold :: 1997 540i 6speed: Sold :: 1995 M3ti 5speed: Sold :: 1997 328i 5speed: Sold ::
  • Court M3
    • Jan 2004
    • 6713
    bosch supers for spark plugs
    K&N filter for airbox
    everything else is waste IMO
    Continuous For Sale Thread
    323i s50
    • VWGolfDriv3r
      • May 2007
      • 34
      How about low temp thermostats?
      • Ahheck01
        • Aug 2004
        • 185
        I know for e36's there's a stuarts water pump - is there an equivalent for the e30?
        -Evan
          • 34847
          the stock E30 stuff is fine
          I would even argue that a K&N filter is a waste of money
          • Sean
            • 5793
            Stock is fine, and the K&N probably doesn't do much.
            There's no optional waterpump. E36's have the different pump because the stock one has plastic parts. E30's use entirely metal water pumps. And they get changed with the timing belt everything 50,000-60,000 miles anyway.
            - Sean Hayes
            • MoparJ
              • May 2007
              • 258
              You didn't list spark plug wires, but I'm working on a way to use generic aftermarket performance wires (Accel, MSD) but retain the stock terminals and boots so they will work with the stock distributor cap. I snipped some wires at the junkyard to experiment with; I just need to find the time to look them over.
              Jason
              • AlarmedBread
                • Sep 2006
                • 1510
                I used an msd kit from autozone, $25, rented the crimping tools there to use the ends off my old wires. Make sure you get ones that your impulse sensor will fit over if you have one.
                • MoparJ
                  • May 2007
                  • 258
                  Nice, that sounds like a good way to go. My car doesn't have the sensor, so that will make things easier.
                  Jason
