individual throttle bodies
  • homegrone30
    • Jun 2007
    • 1449
    has anybody ever done individual throttle bodies on a e30 if so is there a kit 4 it im getting plans together for a drifter and i would like to go that route.
    ne body got a clue?
  • Teaguer
    • Sep 2004
    • 6167
    Originally posted by homegrone30
    ne body got a clue?
    Not you if you are turning an Eta into a drifter .
    About the ITB's , the most well known "kit" is from German tuner Dbillas and the set-up will cost about 10 times what your Eta is worth . Seriously .
    Most that insist on running ITB's will get them from big displacement sportbikes like the Hyabusa and fab up their own set-up .
    To see a set like this check out out John Volks site 666fabrication .
    • homegrone30
      • Jun 2007
      • 1449
      yeh i was wonderin i just think it would be sweet
      • euroshark
        • Apr 2006
        • 3491
        I would recommend not wasting the time and effort, just go turbo.
        • Erick
          Official R3V Drifter
          • 11169
          ^ What he said.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • Jscotty
            • Jan 2007
            • 2285
            Screw the turbo. Just get a bottle.
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              Screw a bottle, just cut the floorboards and go flintstone style...
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • broke30
                • May 2007
                • 1019
                You win...
                On a serious note, there is something to be said for a well tuned NA setup, I have done 2 turbo setups on other cars and the outcome just isn't as rewarding.... Either way there are many who believe that you can easily match and outperform any ITB setup with an equally better plenum setup....
                Max
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  i have the dbilas itb's on my 2.7 stroker ,very nice setup. although, the tps is in a shitty spot if it goes bad, the manifold slightly overlaps the heater core outlet, and you should go with a maf conversoin also if you go this route. i have the old style split second piggyback controler (the one with the 4 knobs) not the greatest set-up in the world. wolf engine mgmt. is comming out with a stand alone that can control just about any function you need it too (a/c ETC ETC). they are also offering it with a plug and play harness for the e-30's. their system will allow you to go to a speed density set up and ditch the maf altogether. still waiting for this to come available to switch over though.
                  • homegrone30
                    • Jun 2007
                    • 1449
                    Originally posted by broke30
                    You win...
                    Max
                    that what im saying i would love to look under my hood and see six throttle bodies plus no turbo lag on another note any known pro chargers on an e30
                    • Ryosuke
                      • Jun 2007
                      • 20
                      Have you considered going with a triple sidedraft carb setup with a standalone ignition system? Not too expensive and you'll get the ITB sound with great throttle response plus it's very simple to tune. ITBs are just way to expensive and the turbo does give better power, plus if you size the turbo properly you won't get as much lag as many people think and you get plenty of usable power. For a badass NA I'd go with carbs for sure.
                      • mcgrath
                        • May 2004
                        • 445
                        Show me where to get an m20 triple side draft manifold.
                        • Tony
                          • 92
                          Dbilas sells just the manifold
                          • mcgrath
                            • May 2004
                            • 445
                            yeah, thats not in the US. Plus price the manifold, then 3 weber 45's cost will be similar to an ITB setup.
                            • swimstarguy
                              • 131
                              Didn't the e21 have a carb'd m20? Can something from that be used? I know the displacement was 2L I have suspicions that the carbs might be too small. But something should work.
                              ~Zar4
