2.7i build questions, please help.
  • TopOfTheLine89
    • Jun 2007
    • 919
    I have searched and found some answers but no clear ones so...
    I have a 87 325 2.7.
    1: What is neccesary to make it a 6250 rpm motor.
    2: Can i swap an IS head? ( i heard that you could only do this on super E'S?
    3: any other good options/swaps to increase rev range.
    97 tacoma 5 spd 4 cylinder
    2001 330ci 5 speed
    83 733i 5 speed, (FS)
  • blazing
    • 274
    Swapping an i head to a non super eta shortblock would produce a low compression ratio.
    To rev higher you would need an I intake setup and a euro head(I don't know the casting number off the top of my head)and a a chip.
    Ideally you could use super eta pistons with your current crank and an i head
    to get good results.
    • ColdAccord
      • 5926
      there have been a million threads on this, should be pretty easy to find.
      putting an i head on there will yield too low c/r. you need custom pistons. like the 10.2:1 mahle pistons I have for sale in my thread in the classifieds.
      Originally posted by blunt
      • Hadrian
        • 48
        731... from a 323i
        • doucy2
          • Sep 2006
          • 1311
          b18 swap FTW, V-TECH Yo!!!
          • NomadE30
            • Mar 2007
            • 236
            Very true there is many thread. Second Hard to find the right answers. The best way to figure out if this or those pistons will work is simply by building the motor and checking clearances
              • 37832
              Use your Eta block, 88 Super Eta pistons, Eta or Super Eta rods, and an i head, wiring, and ECU.
              There you go, a 2.7i using OEM parts.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • ColdAccord
                • 5926
                or spend 550 on pistons and get more p0w4h. my pistons, a cam, and an maf will get you along quite nicely
                • TopOfTheLine89
                  • Jun 2007
                  • 919
                  ok, thanks to everyone for answering, the pistons were the main thing i nereded to know, there is a 325 is at my uncle junkyard i could pick up cheap and rebuilt if i don't want to go swap crazy.
                  2001 330ci 5 speed
                  • NomadE30
                    • Mar 2007
                    • 236
                    does your pistons have the rods with them or not, and what rods would you use and are they made to match a I head or e head?
                    • viali8
                      • Nov 2005
                      • 673
                      this might be helpful
                      • viali8
                        • Nov 2005
                        • 673
                        • viali8
                          • Nov 2005
                          • 673
                          sorry i cant get this link to work
